Zum Hauptinhalt wechseln
Einleitung
If the button on an Atari Flashback 2 joystick is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the joystick in order to access the button to do so efficiently.
  1. Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  5. Remove the  button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
Abschluss
Daniel Hoffman
209 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G2, Hope Fall 2018 Mitglied von Washington State, Team S1-G2, Hope Fall 2018
WSU-HOPE-F18S1G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 64
