Zum Hauptinhalt wechseln
AuKing M8-F Motherboard Replacement
Was du brauchst
  1. AuKing M8-F Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 AuKing M8-F Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. AuKing M8-F Motherboard Replacement: Schritt 2, Bild 1 von 3 AuKing M8-F Motherboard Replacement: Schritt 2, Bild 2 von 3 AuKing M8-F Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
  3. AuKing M8-F Motherboard Replacement: Schritt 3, Bild 1 von 3 AuKing M8-F Motherboard Replacement: Schritt 3, Bild 2 von 3 AuKing M8-F Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Flip up the black locking flaps then remove the two ribbon cables.
  4. AuKing M8-F Motherboard Replacement: Schritt 4, Bild 1 von 2 AuKing M8-F Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
  5. AuKing M8-F Motherboard Replacement: Schritt 5, Bild 1 von 2 AuKing M8-F Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
Abschluss
Jennifer Vazquez
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 124
