Zum Hauptinhalt wechseln
Audio Technica ATH-AD500 Driver Replacement
Was du brauchst
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: Schritt 1, Bild 1 von 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: Schritt 2, Bild 1 von 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: Schritt 3, Bild 1 von 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: Schritt 4, Bild 1 von 1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: Schritt 5, Bild 1 von 1
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: Schritt 6, Bild 1 von 2 Audio Technica ATH-AD500 Driver Replacement: Schritt 6, Bild 2 von 2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Wie man Lötverbindungen herstellt und entlötet.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: Schritt 7, Bild 1 von 2 Audio Technica ATH-AD500 Driver Replacement: Schritt 7, Bild 2 von 2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Levy
177 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-19, Forte Winter 2013 Mitglied von Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Mitglieder
17 Anleitungen geschrieben
2 Kommentare
where can i buy a replacement driver?
acidxgangster - Antwort
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 39
Insgesamt: 10,873
