Einleitung
This guide will help your install a new driver.
Was du brauchst
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Wie man Lötverbindungen herstellt und entlötet.
Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
where can i buy a replacement driver?
You can order parts directly from PARTS@ATUS.COM
