Zum Hauptinhalt wechseln
Audio Technica ATH-AD500 Right Headphone Cable Replacement
Was du brauchst
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: Schritt 1, Bild 1 von 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: Schritt 2, Bild 1 von 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: Schritt 3, Bild 1 von 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: Schritt 4, Bild 1 von 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: Schritt 4, Bild 2 von 2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference Wie man Lötverbindungen herstellt und entlötet.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: Schritt 5, Bild 1 von 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: Schritt 5, Bild 2 von 2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference Wie man Lötverbindungen herstellt und entlötet.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Melanie Reis
227 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-19, Forte Winter 2013 Mitglied von Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Mitglieder
17 Anleitungen geschrieben
3 Kommentare
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - Antwort
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - Antwort
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 4,696
