Zum Hauptinhalt wechseln
Auking M8-F PCB Button Panel Replacement
Was du brauchst
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: Schritt 1, Bild 1 von 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: Schritt 1, Bild 2 von 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: Schritt 2, Bild 1 von 2 Auking M8-F PCB Button Panel Replacement: Schritt 2, Bild 2 von 2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: Schritt 3, Bild 1 von 2 Auking M8-F PCB Button Panel Replacement: Schritt 3, Bild 2 von 2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: Schritt 4, Bild 1 von 3 Auking M8-F PCB Button Panel Replacement: Schritt 4, Bild 2 von 3 Auking M8-F PCB Button Panel Replacement: Schritt 4, Bild 3 von 3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
Abschluss
Aubrey Haynes
277 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 84
