Zum Hauptinhalt wechseln
Axess TA2513-10WT Camera Replacement
Was du brauchst
  1. Axess TA2513-10WT Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
    Frag FixBot
  2. Axess TA2513-10WT Camera Replacement: Schritt 2, Bild 1 von 3 Axess TA2513-10WT Camera Replacement: Schritt 2, Bild 2 von 3 Axess TA2513-10WT Camera Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
    Frag FixBot
  3. Axess TA2513-10WT Camera Replacement: Schritt 3, Bild 1 von 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
    Frag FixBot
  4. Axess TA2513-10WT Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
    Frag FixBot
  5. Axess TA2513-10WT Camera Replacement, Camera: Schritt 5, Bild 1 von 1
    • Turn the tablet over. Locate the left screw.
    • Use the magnetic screwdriver to remove the left screw.
    Frag FixBot
  6. Axess TA2513-10WT Camera Replacement: Schritt 6, Bild 1 von 1
    • There is a bottom screw located to the right of the left screw that was just removed.
    • Remove the bottom screw using the magnetic screwdriver.
    Frag FixBot
  7. Axess TA2513-10WT Camera Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove the entire plastic cover using either tweezers or your fingers.
    Frag FixBot
  8. Axess TA2513-10WT Camera Replacement: Schritt 8, Bild 1 von 1
    • Brush the surfaces of the cameras to remove any debris that is present.
    Frag FixBot
  9. Axess TA2513-10WT Camera Replacement: Schritt 9, Bild 1 von 1
    • There is a black plastic cover on the back of the tablet. It is attached to the ribbon cable.
    • Use tweezers to rotate the black plastic cover 90 degrees upwards.
    • Flip the cover up and pull out the ribbon cable.
    Frag FixBot
  10. Axess TA2513-10WT Camera Replacement: Schritt 10, Bild 1 von 1
    • Remove the ribbon cable from the port.
    Frag FixBot
Abschluss
Steven Kavanagh
301 Reputation
3 Anleitungen geschrieben
Baylor, Team 6-3, Shaver Spring 2015 Mitglied von Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 448
