Zum Hauptinhalt wechseln
Einleitung
The charger port is located on the motherboard (the blue L-shaped piece) at the bottom of the device. In order to replace the port, a soldering kit is needed. Be sure you have all the necessary tools and safety equipment on hand before starting.
A guide to soldering can be found on iFixit's website here.
  1. Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Pry open back piece with plastic spudger. Remove the back piece of the device.
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Gently pry the battery off of the device with the plastic spudger.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  6. The charger port is located on the underside of the motherboard (as pictured).
    • The charger port is located on the underside of the motherboard (as pictured).
  7. Remove the charger port by using tweezers and gently pulling.
    • Remove the charger port by using tweezers and gently pulling.
  8. Solder and place new charger port.
    • Solder and place new charger port.
Abschluss
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
541 Reputation
4 Anleitungen geschrieben
Colorado Springs, Team 2-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 396
