Zum Hauptinhalt wechseln
Azpen A701 Speaker Replacement
Was du brauchst
  1. Azpen A701 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Wedge plastic spudger in between the back panel and the speaker of the device.
  2. Azpen A701 Speaker Replacement: Schritt 2, Bild 1 von 2 Azpen A701 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Gently pry out the speaker from the back panel using the plastic spudger.
  3. Azpen A701 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Heat solder and apply to the wires where they attach to the motherboard. This will disconnect the wires from the motherboard.
    • The wires should still be attached to the speaker.
  4. Azpen A701 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Take the speaker and wires that are attached out of the device and insert a new speaker by soldering the wires to the motherboard.
Abschluss
To reassemble your device, snap back piece back on to device and secure both 2cm screws at the bottom.
Grant Harding
249 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 2-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 127
