Einleitung
Replacing the speaker requires the use of a soldering kit. A guide to soldering is available on iFixit's website here.
Was du brauchst
Wedge plastic spudger in between the back panel and the speaker of the device.
Heat solder and apply to the wires where they attach to the motherboard. This will disconnect the wires from the motherboard.
Take the speaker and wires that are attached out of the device and insert a new speaker by soldering the wires to the motherboard.
To reassemble your device, snap back piece back on to device and secure both 2cm screws at the bottom.
