Zum Hauptinhalt wechseln
Azpen A720 Speaker Replacement
Was du brauchst
    1. Azpen A720 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Azpen A720 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Frag FixBot
      Kommentar hinzufügen
    2. Azpen A720 Speaker Replacement: Schritt 2, Bild 1 von 3 Azpen A720 Speaker Replacement: Schritt 2, Bild 2 von 3 Azpen A720 Speaker Replacement: Schritt 2, Bild 3 von 3
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Frag FixBot
    3. Azpen A720 Speaker Replacement: Schritt 3, Bild 1 von 1
      • Remove the rear casing.
      Frag FixBot
    1. Azpen A720 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
      • The speaker is a black oval located in the corner next to the battery.
      Frag FixBot
    2. Azpen A720 Speaker Replacement: Schritt 5, Bild 1 von 1
      • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
      • Remember which lead the black and red wires connect to on the motherboard.
      • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
      Frag FixBot
    3. Azpen A720 Speaker Replacement: Schritt 6, Bild 1 von 1
      • Remove the speaker from the tablet.
      Frag FixBot
Abschluss
Anna
353 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-3, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 539
