Zum Hauptinhalt wechseln
Azpen A720 Speaker Replacement
Was du brauchst
  1. Azpen A720 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Azpen A720 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: Schritt 2, Bild 1 von 3 Azpen A720 Speaker Replacement: Schritt 2, Bild 2 von 3 Azpen A720 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the speaker from the tablet.
Abschluss
Anna
353 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-3, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 245
