Zum Hauptinhalt wechseln
How to replace the Azpen A720 Wi-Fi Antenna
Was du brauchst
  1. How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: Schritt 1, Bild 1 von 2 How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. How to replace the Azpen A720 Wi-Fi Antenna: Schritt 2, Bild 1 von 3 How to replace the Azpen A720 Wi-Fi Antenna: Schritt 2, Bild 2 von 3 How to replace the Azpen A720 Wi-Fi Antenna: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. How to replace the Azpen A720 Wi-Fi Antenna: Schritt 3, Bild 1 von 1
    • Remove the rear casing.
  4. How to replace the Azpen A720 Wi-Fi Antenna, Wi-Fi Antenna: Schritt 4, Bild 1 von 1
    • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
  5. How to replace the Azpen A720 Wi-Fi Antenna: Schritt 5, Bild 1 von 2 How to replace the Azpen A720 Wi-Fi Antenna: Schritt 5, Bild 2 von 2
    • Locate the soldering connection between the wifi antenna and the motherboard.
    • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
    • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
  6. How to replace the Azpen A720 Wi-Fi Antenna: Schritt 6, Bild 1 von 2 How to replace the Azpen A720 Wi-Fi Antenna: Schritt 6, Bild 2 von 2
    • Locate the black sticker connecting the wifi antenna to the battery.
    • Peel the black sticker off of the battery to disconnect the wifi antenna.
    • Remove and replace the defective wire.
Abschluss
Anna
353 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-3, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 1,090
