Zum Hauptinhalt wechseln
Azpen A740 Battery Replacement
Was du brauchst
  1. Azpen A740 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: Schritt 2, Bild 1 von 2 Azpen A740 Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: Schritt 4, Bild 1 von 2 Azpen A740 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
Abschluss
Maile Sinclair
228 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 4-5, Brown Winter 2015 Mitglied von USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,618
