Einleitung
If you can no longer use your Azpen A740 tablet because the battery no longer holds a charge or has malfunctioned, and you cannot use your device as a result, use this guide to replace the battery.
Before beginning this repair, power off your device and unplug from the charger.
Was du brauchst
Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
Use the set of plastic opening tools to separate the inner backing from the electronics.
Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
