Einleitung
If your love of loud music blew out the speaker in your tablet, fear not. This guide will show you how to take out a worn speaker and replace it with a new one.
Was du brauchst
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
After prying open all of the anchoring points, the cover will lift off of the tablet.
Gently peel back the black electrical tape covering the contact points between the speaker wires and the circuit board. The contact points are marked with a red box.
Melt the solder around the contact points with a soldering iron while using a de-soldering wick to absorb the melted solder.
Once the solder is removed from the contact points, pull the wires away from the circuit board contacts.
