Zum Hauptinhalt wechseln
BLU Energy X Motherboard Replacement
Was du brauchst
  1. BLU Energy X Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 BLU Energy X Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 BLU Energy X Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: Schritt 2, Bild 1 von 2 BLU Energy X Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: Schritt 3, Bild 1 von 3 BLU Energy X Motherboard Replacement: Schritt 3, Bild 2 von 3 BLU Energy X Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 BLU Energy X Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: Schritt 5, Bild 1 von 2 BLU Energy X Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: Schritt 6, Bild 1 von 2 BLU Energy X Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: Schritt 7, Bild 1 von 3 BLU Energy X Motherboard Replacement: Schritt 7, Bild 2 von 3 BLU Energy X Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: Schritt 8, Bild 1 von 2 BLU Energy X Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the motherboard up and out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Geoff Wacker
89.961 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 417
