Einleitung
This guide provides steps on how to replace the microphone for the BLU Studio 7.0 II.
Was du brauchst
Locate the seam between the black and silver pieces of the phone.
Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
Disconnect the battery connector using a plastic opening tool or the flat end of a spudger.
Use the flat end of the black spudger to gently lift up the black plastic piece.
Rest the plastic piece against the back of the phone.
Use the precision tweezers to grip the silicone around microphone and pull it from the plastic housing.
The silicone around the microphone comes off easily; grip the red and black wires gently with either your fingers or a precision tweezer and use your other hand to pull off the black silicone piece.
Desolder the contacts for the red and black wires to disconnect the microphone.
