Zum Hauptinhalt wechseln
Beats Solo 3 Battery Replacement
Was du brauchst
  1. Beats Solo 3 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Beats Solo 3 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: Schritt 2, Bild 1 von 1
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: Schritt 3, Bild 1 von 2 Beats Solo 3 Battery Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: Schritt 4, Bild 1 von 2 Beats Solo 3 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
University of Alabama, Team 1-2, Bedsole Spring 2022 Mitglied von University of Alabama, Team 1-2, Bedsole Spring 2022
UA-BEDSOLE-S22S1G2
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Where too buy battery?
GSD - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 29
Letzte 7 Tage: 145
Letzte 30 Tage: 637
Insgesamt: 12,422
