Zum Hauptinhalt wechseln
Beats Solo 3 Left Hinge Replacement
Was du brauchst
  1. Beats Solo 3 Left Hinge Replacement, Left Hinge Replacement: Schritt 1, Bild 1 von 1
    • Use a spudger or opening tool to peel the earpad away from the left earcup.
    • Remove the tape around the earcup.
    • Make sure to do this step gently to avoid damage to the headphones.
    • Using a plastic or nylon prying tool is recommended to avoid damaging the device.
  2. Beats Solo 3 Left Hinge Replacement: Schritt 2, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three screws from the left earcup.
    • Gently remove the speaker.
    • The speaker is connected to the motherboard by soldered wires so don't pull or yank the speaker off the earcup.
  3. Beats Solo 3 Left Hinge Replacement: Schritt 3, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a Phillips #00 screwdriver to remove two 0.4 mm screws that are holding down the audio jack's circuit board.
    • Use a set of tweezers to gently pull out the audio jack board.
  4. Beats Solo 3 Left Hinge Replacement: Schritt 4, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 4, Bild 2 von 2
    • Use a soldering iron to desolder the seven wires attached to the audio jack board from the the left ear cup.
    • The two wires coming directly from the speaker to the audio jack do not need to be desoldered.
  5. Beats Solo 3 Left Hinge Replacement: Schritt 5, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 5, Bild 2 von 2
    • Use a prying tool to separate the headphone cover.
    • Gently pry up and around the cover to ensure it comes off without breaking.
    • A plastic or nylon prying tool should be used rather than a screwdriver or metal spudger.
  6. Beats Solo 3 Left Hinge Replacement: Schritt 6, Bild 1 von 1
    • Now that the outer and inner panels are separated, pull the desoldered wires through the back of the inner panel.
  7. Beats Solo 3 Left Hinge Replacement: Schritt 7, Bild 1 von 1
    • To disconnect the three bundled connectors from the circuit board of the outer panel, pull the cables away from the socket in the same direction as the individual wires.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  8. Beats Solo 3 Left Hinge Replacement: Schritt 8, Bild 1 von 1
    • Gently pull the wires glued to the headband up.
    • You may use a small pry tool to wedge under the wires.
  9. Beats Solo 3 Left Hinge Replacement: Schritt 9, Bild 1 von 1
    • Pull back the rubber surrounding the left hinge.
    • Use a Phillips #00 to remove two 0.3 mm screws from the left hinge.
  10. Beats Solo 3 Left Hinge Replacement: Schritt 10, Bild 1 von 1
    • Pull the hinge out from the headband.
    • If the hinge is severely broken, it may come out in several parts.
  11. Beats Solo 3 Left Hinge Replacement: Schritt 11, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 11, Bild 2 von 2
    • Fold the hinge and expose the metal pins holding it in place.
    • Use a set of tweezers to remove one of the metal pins.
    • Keep it for later use.
  12. Beats Solo 3 Left Hinge Replacement: Schritt 12, Bild 1 von 1
    • Separate the hinge from the bracket and remove them from the wires.
  13. Beats Solo 3 Left Hinge Replacement: Schritt 13, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 13, Bild 2 von 2
    • Take your replacement hinge in hand and use tweezers to insert the copper plate it comes with.
    • Push the plate down into the hinge's inner groove.
    • This may require some force.
  14. Beats Solo 3 Left Hinge Replacement: Schritt 14, Bild 1 von 3 Beats Solo 3 Left Hinge Replacement: Schritt 14, Bild 2 von 3 Beats Solo 3 Left Hinge Replacement: Schritt 14, Bild 3 von 3
    • Feed the wires through the new hinge and bracket.
    • Clip the hinge and bracket together.
    • Fold the hinge and carefully insert its metal pin.
  15. Beats Solo 3 Left Hinge Replacement: Schritt 15, Bild 1 von 2 Beats Solo 3 Left Hinge Replacement: Schritt 15, Bild 2 von 2
    • Insert the hinge into the headband.
    • Pull back the rubber surrounding the hinge.
    • Use a Phillips #00 screwdriver to replace the two 0.3 mm screws that fasten the hinge to the headband.
    • Congratulations you have replaced the hinge! You may cycle back through the steps to complete reassembling.
Abschluss
  • To reassemble your device, follow these instructions in reverse order.
Samuel Moore
258 Reputation
1 Anleitung geschrieben
York University, Team M-19, Allen Winter 2023 Mitglied von York University, Team M-19, Allen Winter 2023
YORK-ALLEN-W23SMG19
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 62
Letzte 30 Tage: 273
Insgesamt: 3,944
