Einleitung
This guide explains how to replace the left hinge of the Beats by Dre Solo3 headphones. The model number of these headphones is A1796. A faulty hinge is one of the leading causes that render these headphones unusable. Although the hinge is a simple component of the headphones, this repair is not for the light-hearted and will definitely take some time and technical skill to complete.
Required special skills:
- Soldering/desoldering the wires
- Screwing/unscrewing the screws
Note:
- Using a plastic or nylon pry tool is highly recommended when taking apart the device to ensure no damages occur.
- Before beginning, make sure to power off your headphones completely and disconnect from any external power source.
- Be extremely cautious when working around the wires because if they are nicked or damaged during the repairing process the device will no longer be useable and is a fire hazard.
- For more information on soldering, refer to this How to Solder and Desolder Connections guide.
Was du brauchst
Use a spudger or opening tool to peel the earpad away from the left earcup.
Remove the tape around the earcup.
Use a Phillips #00 screwdriver to remove the three screws from the left earcup.
Gently remove the speaker.
Use a soldering iron to desolder the seven wires attached to the audio jack board from the the left ear cup.
Now that the outer and inner panels are separated, pull the desoldered wires through the back of the inner panel.
To disconnect the three bundled connectors from the circuit board of the outer panel, pull the cables away from the socket in the same direction as the individual wires.
Pull back the rubber surrounding the left hinge.
Use a Phillips #00 to remove two 0.3 mm screws from the left hinge.
Fold the hinge and expose the metal pins holding it in place.
Use a set of tweezers to remove one of the metal pins.
Take your replacement hinge in hand and use tweezers to insert the copper plate it comes with.
Push the plate down into the hinge's inner groove.
Feed the wires through the new hinge and bracket.
Clip the hinge and bracket together.
Fold the hinge and carefully insert its metal pin.
Insert the hinge into the headband.
Pull back the rubber surrounding the hinge.
Use a Phillips #00 screwdriver to replace the two 0.3 mm screws that fasten the hinge to the headband.
- To reassemble your device, follow these instructions in reverse order.
