Zum Hauptinhalt wechseln
Beats Studio 2 Wireless Battery Replacement
Was du brauchst
  1. Beats Studio 2 Wireless Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Beats Studio 2 Wireless Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: Schritt 2, Bild 1 von 2 Beats Studio 2 Wireless Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: Schritt 5, Bild 1 von 3 Beats Studio 2 Wireless Battery Replacement: Schritt 5, Bild 2 von 3 Beats Studio 2 Wireless Battery Replacement: Schritt 5, Bild 3 von 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jack Wilson
494 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 40
Letzte 30 Tage: 180
Insgesamt: 2,313
