Zum Hauptinhalt wechseln
Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement
Was du brauchst
  1. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: Schritt 1, Bild 1 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: Schritt 1, Bild 2 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 2, Bild 1 von 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
    Frag FixBot
  3. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 3, Bild 1 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 3, Bild 2 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 3, Bild 3 von 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
    Frag FixBot
  4. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 4, Bild 1 von 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
    Frag FixBot
  5. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 5, Bild 1 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 5, Bild 2 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 5, Bild 3 von 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
    Frag FixBot
  6. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: Schritt 6, Bild 1 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: Schritt 6, Bild 2 von 3 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: Schritt 6, Bild 3 von 3
    • Locate the two solder points corresponding to the malfunctioning vibrational motor.
    Frag FixBot
  7. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 7, Bild 1 von 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Desolder the two connection points corresponding to the malfunctioning vibration motor.
    • Once the solder has been sufficiently melted, carefully pull the wires away from the solder point with tweezers.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 546
