Was du brauchst
unscrew two Phillips screws on each side of the BCD3000
If the screws sit too tight, you can use the extension for better torque
Lift the upper control part.
Disconnect the cables by walking them out of their sockets.
Disconnect the separate boards.
Now you can take the modules out by unscrewing them from the case.
The jog wheels on the front panel can be taken off by using a spudger and levering them out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
great stuff, with better quality pictures would be better
