Zum Hauptinhalt wechseln
Bissell Air180 Motherboard Replacement
Was du brauchst
  1. Bissell Air180 Motherboard Replacement, Air Filter: Schritt 1, Bild 1 von 2 Bissell Air180 Motherboard Replacement, Air Filter: Schritt 1, Bild 2 von 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Motherboard Replacement, Power Supply: Schritt 4, Bild 1 von 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Motherboard Replacement: Schritt 5, Bild 1 von 3 Bissell Air180 Motherboard Replacement: Schritt 5, Bild 2 von 3 Bissell Air180 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Motherboard Replacement, Control Buttons: Schritt 6, Bild 1 von 3 Bissell Air180 Motherboard Replacement, Control Buttons: Schritt 6, Bild 2 von 3 Bissell Air180 Motherboard Replacement, Control Buttons: Schritt 6, Bild 3 von 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Motherboard Replacement: Schritt 7, Bild 1 von 2 Bissell Air180 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Motherboard Replacement: Schritt 8, Bild 1 von 2 Bissell Air180 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Motherboard Replacement, Fan: Schritt 9, Bild 1 von 3 Bissell Air180 Motherboard Replacement, Fan: Schritt 9, Bild 2 von 3 Bissell Air180 Motherboard Replacement, Fan: Schritt 9, Bild 3 von 3
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Motherboard Replacement: Schritt 10, Bild 1 von 2 Bissell Air180 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
  11. Bissell Air180 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 2 Bissell Air180 Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Apply pressure and push out the control knob to remove the motherboard from the rest of the device.
    • Removing the two 11mm Phillips #1 screws when disconnecting the fan also disconnected the motherboard from the rest of the device.
Abschluss
Aleah Ramos
533 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Mitglied von UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 Mitglieder
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 122
