Zum Hauptinhalt wechseln
Black and Decker CM0700BZ Water Tank Replacement
Was du brauchst
  1. Black and Decker CM0700BZ Water Tank Replacement, Lid: Schritt 1, Bild 1 von 2 Black and Decker CM0700BZ Water Tank Replacement, Lid: Schritt 1, Bild 2 von 2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Water Tank Replacement: Schritt 2, Bild 1 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 2, Bild 2 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 2, Bild 3 von 3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Water Tank Replacement: Schritt 3, Bild 1 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 3, Bild 2 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 3, Bild 3 von 3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Water Tank Replacement: Schritt 4, Bild 1 von 2 Black and Decker CM0700BZ Water Tank Replacement: Schritt 4, Bild 2 von 2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Water Tank Replacement: Schritt 5, Bild 1 von 1
    • To also remove the shower head, use the Shower Head guide.
  6. Black and Decker CM0700BZ Water Tank Replacement, Water Tank: Schritt 6, Bild 1 von 2 Black and Decker CM0700BZ Water Tank Replacement, Water Tank: Schritt 6, Bild 2 von 2
    • Remove the carafe holder from the bottom of the coffee machine.
  7. Black and Decker CM0700BZ Water Tank Replacement: Schritt 7, Bild 1 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 7, Bild 2 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 7, Bild 3 von 3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
  8. Black and Decker CM0700BZ Water Tank Replacement: Schritt 8, Bild 1 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 8, Bild 2 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 8, Bild 3 von 3
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  9. Black and Decker CM0700BZ Water Tank Replacement: Schritt 9, Bild 1 von 1
  10. Black and Decker CM0700BZ Water Tank Replacement: Schritt 10, Bild 1 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 10, Bild 2 von 3 Black and Decker CM0700BZ Water Tank Replacement: Schritt 10, Bild 3 von 3
    • Remove the four 10 mm Phillips #1 screws.
    • Slowly pull the water tank up to expose the water pipes
  11. Black and Decker CM0700BZ Water Tank Replacement: Schritt 11, Bild 1 von 2 Black and Decker CM0700BZ Water Tank Replacement: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Squeeze on the prongs with tweezers and hold.
    • Pull the water tank while squeezing the tighteners to loosen the water pipes off of the water tank.
Abschluss
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 Mitglied von UMass Dartmouth, Team 1-2, Shaddix Spring 2023
UMASSD-SHADDIX-S23S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 248
