Einleitung
The water tank may become damaged overtime, or need to be removed for a thorough cleaning. This guide will show the steps of removing the water tank fully from the coffee machine.
Was du brauchst
Place your finger, screwdriver, or spudger behind the corner of the tab.
Pull up on the tab until it disconnects from the coffee maker.
Hold the tab while pushing back on the lid.
The lid should open fully with the top of the lid facing down.
Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
Pry facing away from the lid to force the peg out.
Hold the lid and pull it away from the other insert.
Place coffee maker on its side, with the bottom facing you.
Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
Follow Step #4 of the Power Button Replacement guide, but leave the button in the machine.
Remove the four 10 mm Phillips #1 screws.
Slowly pull the water tank up to expose the water pipes
