Einleitung
Use this guide to remove or replace the charging port in your Black and Decker LI2000.
Was du brauchst
Remove the following five screws
Three 20 mm Phillips #1 screws
One 10 mm #000 Phillips screw
One 13 mm Phillips 31 screw
Refer to the Soldering Technique Guide to remove the wires at the charging port by heating the existing solder on the contacts.
Eine weitere Person hat diese Anleitung absolviert.
