Einleitung
This guide describes how to replace the Black and Decker PS1800 switch. A soldering gun is necessary to replace the switch. Personal protective equipment is suggested.
Was du brauchst
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Identify the switch in center of the drill.
Remove the screws from the switch.
Remove the switch cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
