Zum Hauptinhalt wechseln
Black and Decker Pivot MAX Power Switch Replacement
Was du brauchst
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: Schritt 1, Bild 1 von 2 Black and Decker Pivot MAX Power Switch Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: Schritt 6, Bild 1 von 1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: Schritt 7, Bild 1 von 1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: Schritt 8, Bild 1 von 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: Schritt 8, Bild 2 von 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: Schritt 8, Bild 3 von 3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: Schritt 9, Bild 1 von 2 Black and Decker Pivot MAX Power Switch Replacement: Schritt 9, Bild 2 von 2
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 908
