Einleitung
This guide provides instructions for the replacement of your Black and Decker TR1278B toaster circuit board.
Was du brauchst
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Use a Phillips head #2 screwdriver to unscrew all five screws that attach the circuit board to the top cover.
Remove the circuit board.
Inspect the circuit board for any burnt or otherwise damaged components.
Use a soldering kit to unsolder the damaged component.
Once the damaged component has been unsoldered from the circuit board, remove (and replace) it.
