Zum Hauptinhalt wechseln
Blu Grand M2 Charging Port Assembly Replacement
Was du brauchst
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: Schritt 1, Bild 1 von 1
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: Schritt 2, Bild 1 von 2 Blu Grand M2 Charging Port Assembly Replacement: Schritt 2, Bild 2 von 2
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: Schritt 3, Bild 1 von 1
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team S1-G3, Luster Fall 2018 Mitglied von Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 503
