Zum Hauptinhalt wechseln
Bose Quiet Comfort 35 II Speaker Driver Replacement
Was du brauchst
  1. Bose Quiet Comfort 35 II Speaker Driver Replacement, Speaker Driver: Schritt 1, Bild 1 von 1
    • Take off the ear cushion pad using the plastic opening tool on the right headphone.
    • This will be done using a prying motion between the cushion pad and the headphone itself.
  2. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 2, Bild 1 von 2 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 2, Bild 2 von 2
    • Take off the ear cover off by peeling the glue back with hands.
  3. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 7-millimeter silver screws on the right earphone using the Phillips #000 to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 5-millimeter silver screws attaching the earphone to the headband using the Phillips #000.
  5. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 5, Bild 1 von 2 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 5, Bild 2 von 2
    • Detach the earpiece from the band to reach the speaker driver with better access.
    • This will be done with your hands. The connecting piece can slide out and allow it to detach.
  6. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 6, Bild 1 von 1
    • Detach the silver cover piece on the outside of the headset using the black stick spudger.
    • This will be done by entering the black stick spudger in an opening and pry the cover piece off.
  7. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 7, Bild 1 von 2 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 5-millimeter black screws using the Phillips #000 around the circuit board.
  8. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 8, Bild 1 von 1
    • Take off the gray on/off switch on the circuit board.
    • This can be done with your fingers. Just pull up on the switch and it should detach.
  9. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 9, Bild 1 von 2 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 9, Bild 2 von 2
    • Pry off the glued ribbon cables with the black stick spudger by entering it below the ribbon cable and pulling it up.
    • This prying motion will allow the ribbon cable to come off safely.
  10. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 10, Bild 1 von 3 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 10, Bild 2 von 3 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 10, Bild 3 von 3
    • Detach the second ribbon wire for the charging cable with your hands by pulling each side of the component to separate it.
    • No extra tools are needed.
  11. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 11, Bild 1 von 1
    • Use the iOpener to loosen the glue on the speaker cover by laying it on top of the glue.
  12. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 12, Bild 1 von 1
    • Pry off the speaker cover using the flathead from the Plastic Spudger Set.
    • Enter the flathead under the plastic speaker cover and pry in an upwards motion.
  13. Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 13, Bild 1 von 2 Bose Quiet Comfort 35 II Speaker Driver Replacement: Schritt 13, Bild 2 von 2
    • De-solder the two speaker wires off of their post.
    • Prior knowledge is needed for this step, it can be very hazardous.
    • You can now reach the speaker driver and replace it with a new part.
Abschluss
kssexton
463 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-2, Harley Fall 2023 Mitglied von IUPUI, Team 1-2, Harley Fall 2023
IUPUI-HARLEY-F23S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 28
Letzte 30 Tage: 169
Insgesamt: 906
