Zum Hauptinhalt wechseln
Bose SoundLink III Treble Speakers Replacement
Was du brauchst
  1. Bose SoundLink III Treble Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose SoundLink III Treble Speakers Replacement: Schritt 2, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose SoundLink III Treble Speakers Replacement: Schritt 3, Bild 1 von 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose SoundLink III Treble Speakers Replacement: Schritt 4, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
  5. Bose SoundLink III Treble Speakers Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Gently peel back the adhesive padding on either side of the inner back panel.
    • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
  6. Bose SoundLink III Treble Speakers Replacement: Schritt 6, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
    • Slide off the outer case.
  7. Bose SoundLink III Treble Speakers Replacement: Schritt 7, Bild 1 von 1
    • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
    • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
  8. Bose SoundLink III Treble Speakers Replacement: Schritt 8, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
    • Now you should be able to lift the top panel off.
  9. Bose SoundLink III Treble Speakers Replacement: Schritt 9, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement: Schritt 9, Bild 2 von 2
    • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
    • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
  10. Bose SoundLink III Treble Speakers Replacement: Schritt 10, Bild 1 von 1
    • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
  11. Bose SoundLink III Treble Speakers Replacement: Schritt 11, Bild 1 von 1
    • Gently disconnect the three cables connected to the motherboard.
    • Remove the motherboard from the device.
  12. Bose SoundLink III Treble Speakers Replacement, Speakers: Schritt 12, Bild 1 von 2 Bose SoundLink III Treble Speakers Replacement, Speakers: Schritt 12, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
    • You may need metal tweezers in order to re-coil the replacement speaker.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Dakoda Sanders
1.558 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 3-2, Wollert Spring 2016 Mitglied von USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hi,
Where can i buy the replacement speakers?
Scott - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 4,972
