Zum Hauptinhalt wechseln
Braven BRV-X Button Module(s) Replacement
Was du brauchst
  1. Braven BRV-X Button Module(s) Replacement, Front Speaker Panel: Schritt 1, Bild 1 von 1
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Button Module(s) Replacement: Schritt 2, Bild 1 von 1
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Button Module(s) Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the outer shell.
  4. Braven BRV-X Button Module(s) Replacement: Schritt 4, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement: Schritt 4, Bild 2 von 2
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Button Module(s) Replacement: Schritt 5, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement: Schritt 5, Bild 2 von 2
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Button Module(s) Replacement: Schritt 6, Bild 1 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 6, Bild 2 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 6, Bild 3 von 3
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Button Module(s) Replacement: Schritt 7, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement: Schritt 7, Bild 2 von 2
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Button Module(s) Replacement: Schritt 8, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Button Module(s) Replacement: Schritt 9, Bild 1 von 1
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Button Module(s) Replacement: Schritt 10, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Button Module(s) Replacement: Schritt 11, Bild 1 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 11, Bild 2 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 11, Bild 3 von 3
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Button Module(s) Replacement: Schritt 12, Bild 1 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 12, Bild 2 von 3 Braven BRV-X Button Module(s) Replacement: Schritt 12, Bild 3 von 3
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
  13. Braven BRV-X Button Module(s) Replacement, Button Module(s): Schritt 13, Bild 1 von 2 Braven BRV-X Button Module(s) Replacement, Button Module(s): Schritt 13, Bild 2 von 2
    • Remove the ribbon cable attached to the main board.
    • Pull from the clip and not from the cable.
  14. Braven BRV-X Button Module(s) Replacement: Schritt 14, Bild 1 von 1
    • Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
  15. Braven BRV-X Button Module(s) Replacement: Schritt 15, Bild 1 von 1
    • Gently lift the button module from the enclosure.
Abschluss
Trey Peterson
301 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G5, Harley Spring 2019 Mitglied von IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 398
