Einleitung
Use this guide to remove the front speaker panel in your device. You’ll need to know how to solder to fully replace the speaker panel in your Braven BRV-X. The How to Solder and Desolder Connections guide may help you with this guide.
Was du brauchst
Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
Pry open the second plate holding in the speaker using a spudger around all sides.
Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
Cut the 22 gauge wire attached in the corner.
Solder the new speaker plate during reassembly.
