Einleitung
Use this guide to replace a damaged or malfunctioning control panel on your Brother IntelliFax-2840. The entire panel is replaced as a unit, including the buttons and display.
Was du brauchst
Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
Repeat for the left side control arm.
While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
Gently pull the control panel cable straight out from its connector.
The control panel should now come free.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
