Zum Hauptinhalt wechseln
Building a Caramel Apple
Was du brauchst
  1. Building a Caramel Apple, Building a Caramel Apple: Schritt 1, Bild 1 von 3 Building a Caramel Apple, Building a Caramel Apple: Schritt 1, Bild 2 von 3 Building a Caramel Apple, Building a Caramel Apple: Schritt 1, Bild 3 von 3
    • Acquire apple, stick, plate, and wax paper
    • Write your name on small plate.
  2. Building a Caramel Apple: Schritt 2, Bild 1 von 2 Building a Caramel Apple: Schritt 2, Bild 2 von 2
    • Insert the stick into the apple near the stem.
  3. Building a Caramel Apple: Schritt 3, Bild 1 von 3 Building a Caramel Apple: Schritt 3, Bild 2 von 3 Building a Caramel Apple: Schritt 3, Bild 3 von 3
    • Dunk the apple in the hot caramel, making sure to coat the whole apple.
    • Remove the apple from the caramel, twisting it in the air, allowing the caramel to cool slightly.
  4. Building a Caramel Apple: Schritt 4, Bild 1 von 1
    • Place the slightly cooled caramel apple on the waxed paper with the stick pointed up.
  5. Building a Caramel Apple: Schritt 5, Bild 1 von 2 Building a Caramel Apple: Schritt 5, Bild 2 von 2
    • Put a ton of toppings on the caramel apple, starting with the dry toppings, then the wet.
  6. Building a Caramel Apple: Schritt 6, Bild 1 von 2 Building a Caramel Apple: Schritt 6, Bild 2 von 2
    • Put the caramel apple in the refrigerator for at least an hour, or leave it out to cool.
  7. Building a Caramel Apple: Schritt 7, Bild 1 von 2 Building a Caramel Apple: Schritt 7, Bild 2 von 2
    • Once the caramel apple has cooled properly, eat it.
    • Use a knife and fork if you must.
Abschluss
If you find yourself feeling ill after eating this delicious item, you know you've made it right.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brett Hartt
127.897 Reputation
143 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
3 Kommentare
Why the !&&* is this on iFixit?
Jake Dupre - Antwort
Why not? It's a fun and seasonal.
Tim Asp -
I quite love Carmel Apples, SOOOO... I love this guide!
Ben Capehart - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 658
