Zum Hauptinhalt wechseln
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
Was du brauchst
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 3, Bild 1 von 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 3, Bild 2 von 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 4, Bild 1 von 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 4, Bild 2 von 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 5, Bild 1 von 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 5, Bild 2 von 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: Schritt 5, Bild 3 von 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
Abschluss
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Mitglied von UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 255
