Zum Hauptinhalt wechseln
Canary CAN100USBK Ethernet PCB Board Replacement
Was du brauchst
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: Schritt 1, Bild 1 von 2 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: Schritt 1, Bild 2 von 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 2, Bild 1 von 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 3, Bild 1 von 3 Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 3, Bild 2 von 3 Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 3, Bild 3 von 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 4, Bild 1 von 2 Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 4, Bild 2 von 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 5, Bild 1 von 2 Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 5, Bild 2 von 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: Schritt 6, Bild 1 von 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 7, Bild 1 von 2 Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 7, Bild 2 von 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: Schritt 8, Bild 1 von 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
Abschluss
Tommy Nguyen
597 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G2, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 910
