Einleitung
Removing the grip is necessary to reach the battery door. This process is safe and easy.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Remove two 6.5 mm black screws from the panel.
Fast fertig!
Abschluss
