Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Removing the side panel with Remote Control Socket is safe and simple. It only requires a screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 4.8 mm black screws above the lens on the front of the camera.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Remove the 4.8 mm black screw on the left side of the camera.
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Remove the front panel by lifting it away from the camera's body.
    • Remove the front panel by lifting it away from the camera's body.
  5. Remove seven 4.25 mm black screws on the bottom panel.
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Remove the bottom panel.
    • Remove the bottom panel.
  7. Remove two 6.5 mm black screws from the panel.
    • Remove two 6.5 mm black screws from the panel.
  8. Remove the plastic remote control socket cap by pulling it straight out.
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Slide panel toward bottom of camera to remove. Slide panel toward bottom of camera to remove.
    • Slide panel toward bottom of camera to remove.
Abschluss
Sterling Vinson
223 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
22 Anleitungen geschrieben
i have this camera and the door that holds the film in will not stay closed because the plastic piece has broken at the release point. Which piece is it that I need to replace?
luederscoupons - Antwort
That's a bit of a bugger. The piece that's broken off is most likely the little "hook" on the "door" (the proper name of this "door" would be "back").
Since this little hook is integral with the back, you'd have to replace the entire back.
If you still have the piece that has broken off, it may be possible to glue it back in place, but you'd have to reinforce it with e.g. a small piece of aluminium sheet cut from a soft drink can or something like that. Use cyanoacrylate glue (otherwise known as "superglue") and make sure the pieces are clean and fit perfectly before applying the glue. You need only a tiny drop.
Flying Dutchman -
The EOS 30 is a film camera and therefore does not have an A/V Port, since it does neither Audio nor Video. The socket near the bottom on the grip side is for a wired remote control.
Flying Dutchman - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 1,514
