Zum Hauptinhalt wechseln
Canon PIXMA iP3600 Ink Cartridges Replacement
  1. Canon PIXMA iP3600 Ink Cartridges  Replacement, Ink Cartridges: Schritt 1, Bild 1 von 1
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Ink Cartridges  Replacement: Schritt 2, Bild 1 von 1
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Ink Cartridges  Replacement: Schritt 3, Bild 1 von 1
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Ink Cartridges  Replacement: Schritt 4, Bild 1 von 1
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Ink Cartridges  Replacement: Schritt 5, Bild 1 von 2 Canon PIXMA iP3600 Ink Cartridges  Replacement: Schritt 5, Bild 2 von 2
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Caitlyn
1.184 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-3, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hi, all the years I've been using original ink but it became so expensive and my cuz gave me generic ones. I've installed it last night but then noticed that my images totally not the same on my writeable dvd's,eg. brown colour images (faces) or yellowish.
Is it because of the generic ink cartridges or is there a problem with the printer.
Please help me urgently?
You can even email me directly msmidt@distell.co.za
Marlin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 4,484
