Zum Hauptinhalt wechseln
Canon Pixma MP480 Data Port Replacement
Was du brauchst
  1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: Schritt 1, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: Schritt 1, Bild 2 von 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Canon Pixma MP480 Data Port Replacement: Schritt 2, Bild 1 von 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Canon Pixma MP480 Data Port Replacement: Schritt 3, Bild 1 von 1
    • Open the front tray.
  4. Canon Pixma MP480 Data Port Replacement: Schritt 4, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 4, Bild 2 von 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Canon Pixma MP480 Data Port Replacement: Schritt 5, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 5, Bild 2 von 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Canon Pixma MP480 Data Port Replacement: Schritt 6, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 6, Bild 2 von 2
    • Pry open the side cover with the plastic opening tool.
  7. Canon Pixma MP480 Data Port Replacement: Schritt 7, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 7, Bild 2 von 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Canon Pixma MP480 Data Port Replacement: Schritt 8, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 8, Bild 2 von 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
  9. Canon Pixma MP480 Data Port Replacement, LCD: Schritt 9, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement, LCD: Schritt 9, Bild 2 von 2
    • Using the plastic opening tool, pry off the top cover of the LCD assembly.
    • Pry around the front and side edges for the easiest removal.
  10. Canon Pixma MP480 Data Port Replacement: Schritt 10, Bild 1 von 1
    • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  11. Canon Pixma MP480 Data Port Replacement: Schritt 11, Bild 1 von 1
    • Gently pull the ribbon cable to remove the LCD completely.
  12. Canon Pixma MP480 Data Port Replacement, Buttons: Schritt 12, Bild 1 von 1
    • Locate the buttons on the top of the printer.
  13. Canon Pixma MP480 Data Port Replacement: Schritt 13, Bild 1 von 1
    • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
  14. Canon Pixma MP480 Data Port Replacement: Schritt 14, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 14, Bild 2 von 2
    • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
  15. Canon Pixma MP480 Data Port Replacement: Schritt 15, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 15, Bild 2 von 2
    • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
  16. Canon Pixma MP480 Data Port Replacement: Schritt 16, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 16, Bild 2 von 2
    • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
  17. Canon Pixma MP480 Data Port Replacement: Schritt 17, Bild 1 von 1
    • Gently pull the LCD screen up to remove it from its fixture.
  18. Canon Pixma MP480 Data Port Replacement: Schritt 18, Bild 1 von 1
    • Use the plastic opening tool to pry off the plastic button assembly.
  19. Canon Pixma MP480 Data Port Replacement: Schritt 19, Bild 1 von 1
    • Gently pull the plastic button assembly up to remove it.
    • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
  20. Canon Pixma MP480 Data Port Replacement: Schritt 20, Bild 1 von 1
    • Remove the ribbon cable connected to the backside of the plastic button assembly.
  21. Canon Pixma MP480 Data Port Replacement: Schritt 21, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 21, Bild 2 von 2
    • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
  22. Canon Pixma MP480 Data Port Replacement: Schritt 22, Bild 1 von 3 Canon Pixma MP480 Data Port Replacement: Schritt 22, Bild 2 von 3 Canon Pixma MP480 Data Port Replacement: Schritt 22, Bild 3 von 3
    • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
    • Gently lift the spring and pull the board out of its plastic button assembly.
  23. Canon Pixma MP480 Data Port Replacement: Schritt 23, Bild 1 von 1
    • Remove the buttons from the plastic button assembly.
  24. Canon Pixma MP480 Data Port Replacement, Data Port: Schritt 24, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement, Data Port: Schritt 24, Bild 2 von 2
    • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
  25. Canon Pixma MP480 Data Port Replacement: Schritt 25, Bild 1 von 2 Canon Pixma MP480 Data Port Replacement: Schritt 25, Bild 2 von 2
    • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
  26. Canon Pixma MP480 Data Port Replacement: Schritt 26, Bild 1 von 1
    • Remove the small plastic clip using the spudger.
  27. Canon Pixma MP480 Data Port Replacement: Schritt 27, Bild 1 von 1
    • Pull the plastic inserts out of the holes in the top and bottom.
  28. Canon Pixma MP480 Data Port Replacement: Schritt 28, Bild 1 von 1
    • Remove the board from the printer by pulling the board towards the back of the printer.
    • This requires effort and time as the board comes out slowly.
Abschluss
Cal Poly, Team 19-41, Regan Winter 2013 Mitglied von Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 2,213
