Einleitung
Replacing the LCD Display should be done when the display has been damaged or it has been determined that the LCD is no longer functioning. This will take some time. Handle the display with care once you reach the component as it is attached to several other vital components.
Was du brauchst
Place thumb on area right next to where it says open and slide to the right to open.
Remove the battery by pushing the orange object outwards; the battery will spring up and out.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Place the camera on to the side that has the image stabilizer label.
Remove the 5.00 mm screws that are on this side using the screwdriver.
Place camera on to the side with the A/V Out Digital Cover facing up.
Remove this visible 5.00 mm screw.
Pull the A/V Out Digital cover back to uncover the next step.
Turn the camera onto the side with the A/V out Digital cover.
Use your finger to pull this tab to the right.
Detach the Motherboard, and then gently pull the motherboard away from the screen.
Eine weitere Person hat diese Anleitung absolviert.
