Einleitung
Having trouble seeing images on the LCD Screen on the back of your Canon PowerShot A80 making it hard to focus on the scene you are trying to photograph?
Follow this guide to learn how to remove and replace the LCD Screen of your Canon PowerShot A80 camera.
Before you begin this repair, turn off your camera and disconnect it from the charger. It's also important to remove the battery beforehand.
Was du brauchst
Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
Gently remove the front and back covers from the screen.
Peel back the plastic circuit cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 weitere Personen haben diese Anleitung absolviert.
