Zum Hauptinhalt wechseln
Canon PowerShot ELPH 150 IS Card/Battery Door Replacement
  1. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: Schritt 1, Bild 1 von 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: Schritt 1, Bild 2 von 2
    • Safety First: Power down your camera by locating the ON/Off button on the top of the camera and holding it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 2, Bild 1 von 1
    • Locate the CARD/BATT. OPEN door on the bottom right of the camera.
  3. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 3, Bild 1 von 1
  4. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 4, Bild 1 von 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 4, Bild 2 von 2
    • With the backplate removed, turn the camera so that the CARD/BATT. OPEN door is face up and to the right. Press down on the door as you slide it to the right. You should hear a click which indicates that the door is unlocked and will freely open.
  5. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 5, Bild 1 von 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 5, Bild 2 von 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: Schritt 5, Bild 3 von 3
    • With the CARD/BATT. OPEN door open, and the backplate off, gently pull the door from a 90 degree angle back towards you. Once you hear a pop ( a sign that one side pin has released), you can slide the door away from you to release the pin on the other side as well. Remove door.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S6-G3, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G3, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G3
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Do you know where I can find the sensor pin for the battery door? My Elph 150 won’t turn on and I was thinking that maybe the culprit. I tried new batteries to no avail, also no power when plugged in via usb. Otherwise any ideas what could have caused it, because the camera is in mint condition.
Kimo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 413
