Einleitung
This installation guide will help you remove your broken LCD and install in a new replacement.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Slide this rubber tab out of the way to reveal the bottom screw.
Remove the two 3.7mm screws.
Remove the two 2.3mm outer screws.
Remove the two 3.8mm screws near the strap bracket.
Remove small panel covering mounting bracket.
Remove door covering memory card.
Grasp sides of front cover and carefully pull the front panel off of the camera.
Remove the plastic flap covering the motherboard.
Using your fingernail, open the black clip holding the ribbon cable.
Grab the ribbon cable and carefully pull it out of slot.
Remove the 2.1mm screw.
Grab the sides of the bottom panel and lift it up to expose the ribbon cable.
Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
Grasp sides of LCD screen and lift off of camera.
