Zum Hauptinhalt wechseln
Canon Selphy CP910 Printer Body Replacement
Was du brauchst
  1. Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: Schritt 1, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: Schritt 1, Bild 2 von 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: Schritt 2, Bild 1 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 2, Bild 2 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 2, Bild 3 von 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: Schritt 3, Bild 1 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 3, Bild 2 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 3, Bild 3 von 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: Schritt 4, Bild 1 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 4, Bild 2 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 4, Bild 3 von 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: Schritt 5, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement, Printer Body: Schritt 5, Bild 2 von 2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: Schritt 6, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement: Schritt 6, Bild 2 von 2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: Schritt 7, Bild 1 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 7, Bild 2 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 7, Bild 3 von 3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: Schritt 8, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement: Schritt 8, Bild 2 von 2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: Schritt 9, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement: Schritt 9, Bild 2 von 2
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: Schritt 10, Bild 1 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 10, Bild 2 von 3 Canon Selphy CP910 Printer Body Replacement: Schritt 10, Bild 3 von 3
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: Schritt 11, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement: Schritt 11, Bild 2 von 2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: Schritt 12, Bild 1 von 2 Canon Selphy CP910 Printer Body Replacement: Schritt 12, Bild 2 von 2
    • The empty case will look like this once all the parts are removed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team 1-6, Rose Winter 2016 Mitglied von UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 71
Insgesamt: 4,269
