Zum Hauptinhalt wechseln
Charging Component on the Base Replacement
Was du brauchst
  1. Charging Component on the Base Replacement, Base: Schritt 1, Bild 1 von 1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Charging Component on the Base Replacement: Schritt 2, Bild 1 von 2 Charging Component on the Base Replacement: Schritt 2, Bild 2 von 2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Charging Component on the Base Replacement, Charging Component on the Base: Schritt 3, Bild 1 von 2 Charging Component on the Base Replacement, Charging Component on the Base: Schritt 3, Bild 2 von 2
    • Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
    • Remove both 5mm Phillips #0 screws to release the metal pieces.
  4. Charging Component on the Base Replacement: Schritt 4, Bild 1 von 1
    • Cut the black and red wires to finish removal, and then solder your new replacement component.
    • For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Han Shih
361 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-3, Harley Fall 2016 Mitglied von IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 308
